Online Now [2618]:
Visitors: 2618
Today: 172022
Total: 31116587
my ride!
tyk3
PostPosted: Thu May 15, 2008 8:52 am    Post subject: Re: my ride! Reply with quote
chili39 wrote:
the rear has a perfect drop. Are you using different springs? subwoffers?
bro,all e30 m40 original the will look like that.front clearance & rear clearance is diffrent.
i disagree la bro chili39,my e30 is also like that,lower at the rear.
have tried many solution such as new absorbers(3 different brands!) and still like that also.
out of say 100 e30's you will find 30 with this problem.only solution is to get a set of lowered springs with a higher height like say 40mm at the rear and 30-35mm at the front.i have a friend with this problem and this seemed to be the only working solution.
chili39
PostPosted: Fri May 16, 2008 1:46 am    Post subject: Re: my ride! Reply with quote
bro tyk3,only m40 will look like that.m20 & others don't have this problem.
mcdy
PostPosted: Fri May 16, 2008 2:27 am    Post subject: Re: my ride! Reply with quote
Pedas nyerrrr
tyk3
PostPosted: Fri May 16, 2008 8:10 am    Post subject: Re: my ride! Reply with quote
well i'll let u c for urself 2nite if u join us for tt la.
i'm fed up la so many time tukar absorbers & spring the rear still the same...
chili39
PostPosted: Fri May 16, 2008 2:07 pm    Post subject: Re: my ride! Reply with quote
bro tyk3,sorry i can't joint u guys for tt coz i from m'cca.no point u change ur absorber coz still the same,change ur spring into lowed spring then it will be the same.just go to eibach web side u will see m40 front drop 35mm rear drop 30mm,for other model front 30mm rear also 30mm.i'll change my spring soon on latter.maybe m40 engine is a 4 potter the engine is lighter than the 6 potter so the front higher.
tyk3
PostPosted: Fri May 16, 2008 7:59 pm    Post subject: Re: my ride! Reply with quote
you're from melaka?
i am using my H & R lah bro...35mm front and back some more! Shocked
chili39
PostPosted: Sat May 17, 2008 4:36 am    Post subject: Re: my ride! Reply with quote
bro tyk3,i look at ur car photo seems like hight is balance.
tyk3
PostPosted: Sat May 17, 2008 4:52 pm    Post subject: Re: my ride! Reply with quote
trust me bro,it aint balanced! Sad
anyway,my wifes familyare from ujong pasir...
chili39
PostPosted: Sun May 18, 2008 6:07 am    Post subject: Re: my ride! Reply with quote
bro tyk3,k...i'll ask my sifu when i meet him.i from tmn merdeka,call me at maxis-6236774 when u are in m'cca i belanja u coffee.
tyk3
PostPosted: Sun May 18, 2008 2:16 pm    Post subject: Re: my ride! Reply with quote
cool...thanks bro.
by the way my number is maxis 2594288.
will take u up on your offer when i'm in melaka.
