Online Now [1377]:
Visitors: 1377
Today: 135025
Total: 31093136
Control arm (e30)
a-boo
PostPosted: Sat May 03, 2008 7:31 pm    Post subject: Control arm (e30) Reply with quote
guys, i have a problem with my control arm, the one that looks like a boomerang? hehehe... There are 3 bushings for lower arm am i right? the one thats connected to the tyre is moving. so the whole thing is moving back n forth. Can the bushing be replaced? or have to change the whole arm? the one i marked in yellow.... how much will it cost? Please advise... Smile
PostPosted: Sat May 03, 2008 8:28 pm    Post subject: Re: Control arm (e30) Reply with quote
Can be changed. The lower arm can last fer a long time, unless u hit something and damaged it. Just ask ur nearest friendly neighborhood parts dealer =)
PostPosted: Sun May 04, 2008 9:54 am    Post subject: Re: Control arm (e30) Reply with quote
yes..can be changed..just bought 1 set yesterday...
PostPosted: Sun May 04, 2008 3:04 pm    Post subject: Re: Control arm (e30) Reply with quote
so how much you bought it for orangebmw?
a-boo
PostPosted: Mon May 05, 2008 4:30 am    Post subject: Re: Control arm (e30) Reply with quote
ya how much is it yesterday?
www.teameighth.com
Sympathy Towards Gravity
PostPosted: Mon May 05, 2008 5:51 am    Post subject: Re: Control arm (e30) Reply with quote
If budget permits, i strongly advise you to buy the whole assembly. But if no budget, then you buy separately. Reason is, if you buy the whole assembly, the control arm is new (besi pun keras lagi) and it was assemble by the factory itself therefore they have a QC on every parts assembled.
The control arm tends to soften due to wear and tear, therefore besi arm tu pun lembut sikit then if you change bushing only... the bushing also will cepat rosak sebab the strength and pressure on the road. mmm... harap2 you paham ler.. gue pun penin kepara nak explain.
Control arm full assembly will cost you somewhere around 300+ one side.
PostPosted: Mon May 05, 2008 3:19 pm    Post subject: Re: Control arm (e30) Reply with quote
ok thanks highwaystar! not that expensive actually...i'm planning to change also...
a-boo
PostPosted: Tue May 06, 2008 7:42 am    Post subject: Re: Control arm (e30) Reply with quote
paham paham.... heheheh... will check out the price...
www.teameighth.com
a-boo
PostPosted: Tue May 06, 2008 6:28 pm    Post subject: Re: Control arm (e30) Reply with quote
price is about rm60 per bushing, its not under BMW's ETK cause its an oem part... Smile
www.teameighth.com
PostPosted: Wed May 07, 2008 6:18 am    Post subject: Re: Control arm (e30) Reply with quote
lower arm rm65..both other bush rm55 each..so rm175...can be used on e36 also
