Online Now [1443]:
Visitors: 1443
Today: 15246
Total: 31144428
stering coupling e30
WakE30Panchur
PostPosted: Thu May 22, 2008 12:56 pm    Post subject: stering coupling e30 Reply with quote
Ada sesiapa simpan barang ni tak? Saya punya dah rosak lah. Any idea how much ? New or potong keleta mari punya. Tq
tyk3
PostPosted: Thu May 22, 2008 1:00 pm    Post subject: Re: stering coupling e30 Reply with quote
bro,call munich auto and ask for mr.siew.
say you're Brad's friend.
his number is 03-4043 2418.
it wont cost much to get it replaced.he will give you a good price.
good luck!
WakE30Panchur
PostPosted: Thu May 22, 2008 1:34 pm    Post subject: Re: stering coupling e30 Reply with quote
good luck!
Thanks tyk3. I call munich alladey. He quote me for new one rm 800.00 lo.
PostPosted: Thu May 22, 2008 1:43 pm    Post subject: Re: stering coupling e30 Reply with quote
????getah?so mahal meh....
PostPosted: Thu May 22, 2008 1:44 pm    Post subject: Re: stering coupling e30 Reply with quote
Okay for e30 steering coupling got two part on which easily worn off. Your steering freeplay longgar then it must be the rubber coupling on which will cost you around RM80 or less than 100
Please refer parts number 3.
I think RM800 is the whole assembly. like number 2, 10, 3, 4, 5
a-boo
PostPosted: Thu May 22, 2008 4:28 pm    Post subject: Re: stering coupling e30 Reply with quote
i recently changed my part no 3. (steering bushing) Rm 80 bucks only...
www.teameighth.com
Sympathy Towards Gravity
PostPosted: Fri May 23, 2008 2:28 am    Post subject: Re: stering coupling e30 Reply with quote
yup, i will change mine soon.... terlampau over drift tu pasal jadi macam tuh...kekeke
Some call bushing and some call rubber coupling.. Good Luck Wak!
PostPosted: Fri May 23, 2008 2:55 am    Post subject: Re: stering coupling e30 Reply with quote
I've got the whole part 2nd hand around RM300 siap pasang. That was 2 years ago hehe =)
PostPosted: Fri May 23, 2008 5:23 am    Post subject: Re: stering coupling e30 Reply with quote
i thought the steering freeplay is due to part number 4 and 5? Any difference if change the bush?
PostPosted: Fri May 23, 2008 5:49 am    Post subject: Re: stering coupling e30 Reply with quote
4 and 5 definately got freeplay but not much. The only thing that worn off is part number 3. If 3 is okay no crack then your freeplay is minimum. If your steering freeplay can go as much as quarter circle (maximum already), then you must change the rubber coupling. firm freeplay is common.
tyk3
PostPosted: Fri May 23, 2008 7:37 am    Post subject: Re: stering coupling e30 Reply with quote
i think u asked for the whole assembly kot?
no way does he charge RM800 for a steering coupling la...
its definately around RM80-100 la...u try call him again.
e30's rule!
WakE30Panchur
PostPosted: Fri May 23, 2008 1:02 pm    Post subject: Re: stering coupling e30 Reply with quote
Thanks Mr Highway for the info. Yes RM 800 for the whole set. If only the rubber, Munich quote me RM 35. Can we change only the rubber err ?Because the forman told me that if I want to change the rubber only, must moodyfight the things. Forman said it around rm 200 above.
PostPosted: Fri May 23, 2008 2:25 pm    Post subject: Re: stering coupling e30 Reply with quote
mmm... have you mod your steering assembly before? mana ada modify? what year is your E30?
WakE30Panchur
PostPosted: Sat May 24, 2008 4:52 pm    Post subject: Re: stering coupling e30 Reply with quote
mmm... have you mod your steering assembly before? mana ada modify? what year is your E30?[/quote]
Dono la Mr Rainer, modify or not. My e30 1985. May be the forman want to ketuk me..
PostPosted: Sat May 24, 2008 5:13 pm    Post subject: Re: stering coupling e30 Reply with quote
maybe he's talking bout steering rack?
