Online Now [1840]:
Visitors: 1840
Today: 136013
Total: 31094124
Comparison Between Gabriel and Blinstein Absorber
moose
PostPosted: Fri Jan 18, 2008 2:41 am    Post subject: Comparison Between Gabriel and Blinstein Absorber Reply with quote
Bro. I need some advice regarding Gabriel and Blinstein Absorber.
I ade tanye supplier, which one is better. Then he advised me to buy Gabriel for my rear absorber . Gabriel Absorber RM150/pcs and Blinstein RM170/pcs.
For your info, I drive e 36 and my rear absorber dah tak sedap
For Gabriel absorber i cuba tekan , keras as compared to blinstein.
Kalau front absorber which one is better blinstein or gabriel , or any suggestion to other brands.
PostPosted: Fri Jan 18, 2008 6:18 am    Post subject: Re: Comparison Between Gabriel and Blinstein Absorber Reply with quote
i used gabriel at front (e30)..a bit keras la compare to sachs...x penah try bilstein lg
threebond
PostPosted: Sun Mar 02, 2008 6:39 am    Post subject: Re: Comparison Between Gabriel and Blinstein Absorber Reply with quote
murah beb..tapi bukan alot of member cakap bilstein ok what. last 2 days i call 1 of supplier. im ask them for my somplete set for my e30. their also promote gabriel. they say Gabriel more keras than bilstein. price pun murah skit.
entah lar..so waht the otai2zz & the members yg penah pakai product ni... opinion.
PostPosted: Sun Mar 02, 2008 4:57 pm    Post subject: Re: Comparison Between Gabriel and Blinstein Absorber Reply with quote
Yub Gabriel is cheaper than Bilstein. What we are talking here is Bilstein Black rite? Gabriel is stiffer (harder). What I know, It's from the USA. For balance ratio and control, I would suggest to stick to 1 type of abs for all 4 tyres.
If you want harder, go for Bilstein Yellow (mooore expensive) or Gabriel. Bilstein Black and a combi with Eibach Pro-kit is a legend. I'm running with that combi too. Comfy and just nice fer cornering too.
Some people like to mix & match. Up to individuals. But, be careful as ur handling & comfy might be compromised =) Good luck.
PostPosted: Sun Mar 02, 2008 6:48 pm    Post subject: Re: Comparison Between Gabriel and Blinstein Absorber Reply with quote
im using bilstein yellow with H&R springs...stiff and not comfy but the handling is heaven!
harry
PostPosted: Sun Mar 02, 2008 8:45 pm    Post subject: Re: Comparison Between Gabriel and Blinstein Absorber Reply with quote
As for me BILSTEIN...why? Cause i notice if you are not using stock engine.
Try not to use stiff cheap abs,thts y it does not last long.You may have super handling but will your body exterior last. It will crack your body kits....trst me.
I experience it...unless banyak $$$$$...
Dnt torture your ride.......let it live......
threebond
PostPosted: Sun Mar 16, 2008 7:51 am    Post subject: Re: Comparison Between Gabriel and Blinstein Absorber Reply with quote
erm.. thanks bro for the info...
c ya..
PostPosted: Fri Apr 11, 2008 2:55 am    Post subject: Re: Comparison Between Gabriel and Blinstein Absorber Reply with quote
Want to know what different H&R spring & Eibach spring?? Cost of both spring??
PostPosted: Fri Apr 11, 2008 7:15 am    Post subject: Re: Comparison Between Gabriel and Blinstein Absorber Reply with quote
H&R is more stiffer and its not as low as Eibach. Eibach is softer. This is my experience. If not mistaken, both springs cost the same at RM1200 brand new. I stand corrected
PostPosted: Fri Apr 11, 2008 8:02 am    Post subject: Re: Comparison Between Gabriel and Blinstein Absorber Reply with quote
Owh...agree with u,Eibach mmg soft & very lowed...good change to H&R,thanks Chris!
PostPosted: Fri Apr 11, 2008 8:11 am    Post subject: Re: Comparison Between Gabriel and Blinstein Absorber Reply with quote
.. but where to get H&R??
PostPosted: Fri Apr 11, 2008 10:38 am    Post subject: Re: Comparison Between Gabriel and Blinstein Absorber Reply with quote
maybe ask Calvin Tan?
loafer
PostPosted: Sun Apr 13, 2008 7:19 am    Post subject: Re: Comparison Between Gabriel and Blinstein Absorber Reply with quote
Hi there...I got my Bilstein B8 + H&R springs from Msport in Sunway. For E36 the H&R spring isn't a perfect fit into the upper cap (dunno what its called but the the top part of the spring rests on the cap) so need some forcing in.
I have yet to sit in a ride that has Eibach springs with Bilstein B8 so I can't make any comparison but from what I've read around in a few other forums, H&R is definitely stiffer compared to Eibach. If you're looking for comfort you should try Eibach.
Alternatively you can go for coilovers KE KE!
PostPosted: Mon Apr 14, 2008 4:03 pm    Post subject: Re: Comparison Between Gabriel and Blinstein Absorber Reply with quote
Hmm...what about Bilstein springs??? Anyone have try this????
PostPosted: Mon Apr 14, 2008 5:55 pm    Post subject: Re: Comparison Between Gabriel and Blinstein Absorber Reply with quote
stick to H&R, u'll be much happy. Eibach also can
