Online Now [1589]:
Visitors: 1589
Today: 56831
Total: 31167973
fed up la
PostPosted: Fri Dec 21, 2007 6:54 pm    Post subject: fed up la Reply with quote
My car during day time will not let me rev high and it will misfire at high rpm. Im really fed up already. Using the diagnosis machine, 3 problems popped up, fuel pump relay, O2 sensor and idle actuator. 2 of the problems are expensive and i really dont have that much money to fix it.
Just changed the engine recently due to broken crankshaft and now all these problems. Aiihhh...Im really fed up with the car. Sorry, just wanna express out my feeling.
PostPosted: Sat Dec 22, 2007 3:48 am    Post subject: Re: fed up la Reply with quote
Aiyooo.. dont fed-up lorrr... why lar? me, xsjado and all the guys here faced their worst day same as you larr... better discover now rather than later larr.. chris.
at the mean time keep your chin up. we try our best to help you out!
dont worry... time will be yours!
"kegagalan adalah satu sukses tertunda"
cheers!
PostPosted: Sat Dec 22, 2007 5:40 am    Post subject: Re: fed up la Reply with quote
i dah muak tertunda la...LAMA GILER i tertunda bro. T_T
PostPosted: Sat Dec 22, 2007 5:43 am    Post subject: Re: fed up la Reply with quote
sabar bro.. nanti kite layan minum teh.. boleh release kepala.. Smile
PostPosted: Sat Dec 22, 2007 10:13 am    Post subject: Re: fed up la Reply with quote
sabar...took me six months to work our my mechanical and electrical glemlins during my engine swap!it will all be worth it!trust me.
PostPosted: Sat Dec 22, 2007 11:57 am    Post subject: Re: fed up la Reply with quote
i found any symptom. Whenever i start to rev high, the temperature indicator will slowly drop to the blueish area. Bear in mind my meter is an M40 meter, therefore the temp gauge and the tachometer keeps on flickers. If i press any further, the car will misfire. Now there's another new problem. After misfire, my car will run like shit.
When i press the accelerator, its like not enough fuel to the engine. Once i stop the car at the side. It seems like the engine is running on 4 cyclinder. Uneven rattling of the engine. I turned off the engine. The engine is fine again until the next misfire.
Helppppp
PostPosted: Sat Dec 22, 2007 7:33 pm    Post subject: Re: fed up la Reply with quote
m40 meter means its calibrated for 4 cylinder tacho reading...flickering may mean that you have grounding and contact issues on you cluster...as for the misfire...DME issues.try someone elses DME...maybe you can trace from there.
PostPosted: Sun Dec 23, 2007 12:01 am    Post subject: Re: fed up la Reply with quote
DME as in ECU? oh god
PostPosted: Sun Dec 23, 2007 6:10 pm    Post subject: Re: fed up la Reply with quote
Don't fed up bro,bwk sabar byk2....bkn sng nk maintain keta lama like e30, walau apa pn problem comes to us it's tetap our proud car!! Semua org penah melalui kesusahan like's ur problem malah lbh teruk dr itu....same like me,so don't worry & take ur time....
PostPosted: Mon Dec 24, 2007 11:42 am    Post subject: Re: fed up la Reply with quote
Problems solved! Misfiring gone!! THe muthafu*ka pulled like a train!
problem? Apparently the socket running underneath the engine manifold is having some difficulty in connection due to particles such as dust, dirt etc etc. I was inspecting the engine last night and wiggled the wires, suddenly the engine just died off. No problem in starting up the car, then wiggled again, the engine almost died.
Today, went to workshop and borrow contact cleaner, sprayed to the socket and other connectors as well, ICV, AFM, brown socket..whatever la! start the car and took it for a test run, ITS ALIVE ITS ALIVE!! I CAN REV WITHOUT MISFIRING!!
PostPosted: Mon Dec 24, 2007 11:44 am    Post subject: Re: fed up la Reply with quote
Thank you so much for the members who chipped in. Appreciated. XD
PostPosted: Mon Dec 24, 2007 4:51 pm    Post subject: Re: fed up la Reply with quote
hah good fer u mate! ... that's why, sometimes it's just lil' thing we just missed out. Chritsmas joy fer u bro =)
PostPosted: Mon Dec 24, 2007 9:36 pm    Post subject: Re: fed up la Reply with quote
not for long bro, although the car now can rev freely, after hard rev, the car is like having fuel starvation, if i let the car idle, the car wants to die off, if i press the throttle, its like slowly going up and misfires. I suspect is the wires on the switch that are bad or corroded...aiyoh...
PostPosted: Mon Dec 24, 2007 10:16 pm    Post subject: Re: fed up la Reply with quote
damn mechanic, busy talking!! Mad
[img][/img]
Dont care la!!! Do myself!! Confused
why la why always got problem... Crying or Very sad
PostPosted: Tue Dec 25, 2007 4:44 pm    Post subject: Re: fed up la Reply with quote
err.. where's is that la bro? IMHO, u should fix the basic problems first i.e. leaking / harden hose etc. Replace the normal wear & tear. And after that you can slowly diagnose for actual prob.
I saw u holding the AFM. Try to move the 'flap' inside it. If it's a lil' bit hard or not smooth to move, then that's one of ur problem. You can also try to 'de-carb' the engine. Who knows the carbon has clogged in there.
You don't like the shop? Ask me or Highwaystar. We try to help u out. Good luck =)
