Online Now [1761]:
Visitors: 1761
Today: 188249
Total: 31128698
Mintak Tolong All Members
reme28
PostPosted: Tue Dec 18, 2007 3:33 am    Post subject: Mintak Tolong All Members Reply with quote
need help please to all of u
sesape ada long shaft (kapling) for e28 520i auto ?
long shaft kawan saya broken.foreman pun dah pening tak boleh baiki.kalau biar lama takut tangkap gearbox plak.kalau ada members disini yang simpan stock kasi tau lah ye atau ada yang nak tolak murah2 tu.
tq
PostPosted: Tue Dec 18, 2007 3:35 am    Post subject: Re: Mintak Tolong All Members Reply with quote
tq
Long Shaft karrr atau Coupling? These are two diffrent things...
if Coupling, i suggest you to buy new.
reme28
PostPosted: Tue Dec 18, 2007 3:39 am    Post subject: Re: Mintak Tolong All Members Reply with quote
tq
my friend said long shaft problem.sebab masa nak jalan mcm ada sangkut sikit.mcm ada gegar dkt gear box.tapi gear box ok.dah cari merata tak ade la bro hywy Crying or Very sad
PostPosted: Tue Dec 18, 2007 3:55 am    Post subject: Re: Mintak Tolong All Members Reply with quote
Please consider to check your Long shaft center bearing. Long shaft are made to last and jarang rosak especially to auto trans. It must be the Center Bearing.
Center bearing characteristic is to dampen / absorb vibration between gearbox to axle (rear gearbox). If the Center bearing spoil, you might encounter a tremendous vibrations while acceleration.
Ask mech to carefully inspect the center bearing, if the bushing crack... (the rubber that holds the bearing) it consider sudah kong.
BUT
If you break then vibration gila-gila... this faulty cause to your lower/upper arm including bushing.
drag86
PostPosted: Fri Dec 28, 2007 4:12 am    Post subject: Re: Mintak Tolong All Members Reply with quote
Bro Highwaystar,
I got my problem (E28) at the speed of 60km+ starts to vibrate, after hitting 80km back to normal. Last check mech. say was the rim, rear left rim not even. Replace rims still the same. Can it be the center coupling or the long shaft. Pls advise. Thanks. Rolling Eyes
