Online Now [1460]:
Visitors: 1460
Today: 56552
Total: 31167694
lantai bocor
E30_320i
PostPosted: Wed Dec 12, 2007 12:01 pm    Post subject: lantai bocor Reply with quote
salam to all sifu2..
mintak pendapat sifu2 semua.. lantai keta aku dah belubang.uwaaa..
masa aku hantar repair keta aritu.. dorang jek keta aku kat lantai.. tak prasan plak.. bila dah balik ujan lakk.. abis basah kapet.. siott je.. menyirap aku..ada tak tempat yg bleh di'rekemenkan'.. area shah alam ke puchong ke..tq
PostPosted: Thu Dec 13, 2007 5:19 am    Post subject: Re: lantai bocor Reply with quote
aku pon lantai mcm ko gak siap nampak tar....tapi aku dah buat balik la....complet cat dgn ketuk body abis 4k lebih gak le.....
PostPosted: Thu Dec 13, 2007 6:15 am    Post subject: Re: lantai bocor Reply with quote
it's a well known problem for a pre-facelift model. It's like the Flinstone car syndrome. Can put your feet down for instant breaking. Good luck on fixing it =)
E30_320i
PostPosted: Thu Dec 13, 2007 10:30 am    Post subject: Re: lantai bocor Reply with quote
HUMANG JANGGG...4K lebih.. boley tuka rim baru tu.. kena buat cepat la cam ni gayanya.. musim ujan nihh kang boleh bela ikan dlm keta aku.. ahakss.. ari minggu aku g antar w/shop..tq semer2..
PostPosted: Thu Dec 13, 2007 12:26 pm    Post subject: Re: lantai bocor Reply with quote
4K lebih tu betul extensive job, some owner, rebuild the whole under carriage and some just patch-up the problem part. Also, some apply Dynamat to extend the life of undercarriage and soundproofing. Fixing yur under carriage price ranging from RM500 to RM4k pun ada. see what is your requirement.
Advise, since budget is limited on your part, just patch-up the corrosive part then apply anti rust compound to whole under carriage surface. Once you had 'Wooonggaa' then go rebuilt your undercarriage.
Mine, only fix the area yang bocor which cost me easily RM400 (lobang duit 50sen 4 tempat).
Good luck!
PostPosted: Fri Dec 14, 2007 5:19 pm    Post subject: Re: lantai bocor Reply with quote
Mine oso lobang at driver site....cost around RM300,kasi buang semua lantai yg reput & tampal lantai baru....now ok!!
PostPosted: Sat Dec 15, 2007 12:33 am    Post subject: Re: lantai bocor Reply with quote
salam bro...
kat puchong prima (kalau tak silap la) ada satu bengkel ketuk & cat. pemiliknya nama atan. nama kedai tak tau pasai tak dak iklan. tapi hasil kerjanya seumpama kereta anda baru kuar dari kilang. dulu ada sorang mat saleh keja kat proton cat celica (TA22) kaler oren berstripe hitam (macam mustang) yang dah di convert kepada 2j. cuba la bertanya.
E30_320i
PostPosted: Sat Dec 15, 2007 10:04 am    Post subject: Re: lantai bocor Reply with quote
Ada ekk.. tadi aku try tanya kat bengkel area sek 26..semer bz.. banyak keta lakk nak kena buat body.. nak melaram raya nnti la tuh.. ahakss.. nanti aku try pegi kat puchong tu.. anyway thanks semers..
E30_320i
PostPosted: Mon Dec 17, 2007 1:52 pm    Post subject: Re: lantai bocor Reply with quote
wakakakakahh... terkena aku.. tadi aku g antar keta kat satu bengkel.. tk smpai 2 jam dia kol aku.. kata keta dah siap.. nak tau apo sobabnye.. hose air air-cond aku tercabut.. jadi air air-cond turun kat bawah karpet belah driver..sioll jer.. berdosa aku maki dalam hati kat apek yg 'jek' keta aku tuhh.. skang dah ok dah keta aku tu.. Razz
PostPosted: Mon Dec 17, 2007 2:28 pm    Post subject: Re: lantai bocor Reply with quote
aiyoo.. aiyoo.. that's an honest mechanic la bro. If he's not, he'll ketuk kaw-kaw bro.. kekekek. Hari Raya Haji pegi mintak maaf kat apek tu kekekek..
PostPosted: Tue Dec 18, 2007 2:15 am    Post subject: Re: lantai bocor Reply with quote
this is tha FUN part...adoiiiii...
Well, syabas and congrats.... you consider settle your problem heh?
E30_320i
PostPosted: Tue Dec 18, 2007 3:32 pm    Post subject: Re: lantai bocor Reply with quote
memang lawak la.. peringatan utk kengkawan semer.. kalu lantai basah, tolong check dulu hose air-cond dulu hahahaha.. so problem aku dh selesai.. thanks semua.. Razz
PostPosted: Wed Dec 19, 2007 3:29 am    Post subject: Re: lantai bocor Reply with quote
tapi lantai aku tu dah tahap flinstone kat 4 tempat tu.....so ketuk balik body sebab ada xsiden skit dgn cat suma tu yg harga camtu....kira body yg mana ada karat suma buat balik...
