Online Now [2247]:
Visitors: 2247
Today: 132918
Total: 31091029
E30 Automatic Gear Box
PostPosted: Thu May 22, 2008 6:18 am    Post subject: E30 Automatic Gear Box Reply with quote
E30 Gearbox Auto 4 Speed for sale (cable driven)
The incomplete things for this gearbox
only the gear lever shifter and knob.
The rest is working perfectly
comes with torque convertor
Selling for RM650 Firm
tyk3
PostPosted: Thu May 22, 2008 11:29 am    Post subject: Re: E30 Automatic Gear Box Reply with quote
brah...will this fit an e34 1989 model m20b20 auto?
also,ada manual punya tak?
PostPosted: Thu May 22, 2008 12:43 pm    Post subject: Re: E30 Automatic Gear Box Reply with quote
i think it will fit in..the only issue here is the longshaft
tyk3
PostPosted: Thu May 22, 2008 12:46 pm    Post subject: Re: E30 Automatic Gear Box Reply with quote
tu lah....got to make sure it fits coz my friend looking for an auto box.
PostPosted: Thu May 22, 2008 12:53 pm    Post subject: Re: E30 Automatic Gear Box Reply with quote
mmmm... m20 e34 is motronic and not cable driven, you have to get the 4 pin auto gearbox. sorry cant fit in
PostPosted: Thu May 22, 2008 4:00 pm    Post subject: Re: E30 Automatic Gear Box Reply with quote
i have one autobox for motronic..but rosak already
it only last about 5months,then kaput already
thats why using manual now
PostPosted: Fri May 23, 2008 2:22 am    Post subject: Re: E30 Automatic Gear Box Reply with quote
how kaput? maybe its the valve body... masuk gear lambat is a valve body problem.
FerMan
PostPosted: Fri May 23, 2008 4:09 am    Post subject: Re: E30 Automatic Gear Box Reply with quote
Does this mean the highwaystar-mobile is gonna convert to manual? =D
PostPosted: Fri May 23, 2008 4:29 am    Post subject: Re: E30 Automatic Gear Box Reply with quote
cant engage to any gear..
masuk 'd' nothing 'r' oso nothing
PostPosted: Fri May 23, 2008 4:37 am    Post subject: Re: E30 Automatic Gear Box Reply with quote
hahaha clutch bakar already lorrr... buleh hantar recycle besi... buleh dapat 200 kot.
Oiittt... converted already lorrrr...hehehehe
PostPosted: Fri May 23, 2008 5:22 am    Post subject: Re: E30 Automatic Gear Box Reply with quote
can change your signature already loh..hehehehe
cabutz~
PostPosted: Fri May 23, 2008 7:11 am    Post subject: Re: E30 Automatic Gear Box Reply with quote
tgk lu org sembang teknikal pasal bm.. pening wa tgk.. sebelum ni kete jepun je.. bm tak penah amek tau.. zero rasanya.. heheh..
PostPosted: Fri May 23, 2008 7:14 am    Post subject: Re: E30 Automatic Gear Box Reply with quote
bro highway.. just want to ask ur opinion.. kalo alternator dah servis.. lepas seminggu bateri asyik kong je.. tu maknanya alternator langsung takbleh pakai ke bro?
PostPosted: Fri May 23, 2008 9:14 am    Post subject: Re: E30 Automatic Gear Box Reply with quote
Check battery level in and out. See charging masuk lebih dari yang keluar.
On engine, air cond, cd player, lampu, lampu highbeam, hazard lights, wiper, sekali gus. Suruh mech angkat amp reader to measure power in (charging in) and power yang discharge. Kalau charging kurang dari yang keluar, alternator kurang baik, kalau power keluar kurang dari charging batteri kong.
Kalau sama okay status that mean ada power leak.
Off semua, termasuk engine. Disconnect Negative, ambil amp meter sambung kan satu wire ke kepala bateri negative, dan satu lagi ke body.
kalau takde reading that mean power takde leak, kalau ada reading maybe power leak. Check wiring alarm, central locking or any other wire that connects like headlamp, signals, cigarette lighter, fuse box bla bla (advisable send to wireman).
Most battery shop know how to check, but wiring better look for wireman. Good luck.
What ampere you using?
if you kaki ice, better change bigger ampere. normal ones around 45amp, mine i change to 90amp.
Okay back to topic
MY GEARBOX FOR SALE!!!!
