Online Now [1123]:
Visitors: 1123
Today: 47381
Total: 31160740
RENAISSANCE OF THE E21
andre1001
PostPosted: Sun Nov 25, 2007 4:40 am    Post subject: Re: RENAISSANCE OF THE E21 Reply with quote
YEP ORI MAN ORI BMW ORIGINAL BAVARIAN BLOOD LA
View user's profile Send e-mail Photo Gallery
PostPosted: Sun Nov 25, 2007 4:44 am    Post subject: Re: RENAISSANCE OF THE E21 Reply with quote
No wonder lah..!!! Hahaha... Again, salute...!!! Wink
andre1001
PostPosted: Sun Nov 25, 2007 4:55 am    Post subject: Re: RENAISSANCE OF THE E21 Reply with quote
CHEERS BRO
andre1001
PostPosted: Sun Nov 25, 2007 5:59 am    Post subject: Re: RENAISSANCE OF THE E21 Reply with quote
HARDEST WORK DONE IN PHOON TRADING WORK SHOP SHAN SOW LIN
TWISTING THE EXHAUST ARROUND THE STEERING COLUMM
PostPosted: Sun Nov 25, 2007 8:57 am    Post subject: Re: RENAISSANCE OF THE E21 Reply with quote
perghhh......respek la............engine ni...............
PostPosted: Sun Nov 25, 2007 1:34 pm    Post subject: Re: RENAISSANCE OF THE E21 Reply with quote
it is such a tight squeeze....
amazing...
andre1001
PostPosted: Sun Nov 25, 2007 4:46 pm    Post subject: Re: RENAISSANCE OF THE E21 Reply with quote
thanks guys should we go for test drive
PostPosted: Sun Nov 25, 2007 5:07 pm    Post subject: Re: RENAISSANCE OF THE E21 Reply with quote
this is the spec of this revolutionary engine, i really dunno how u manage to source this engine in malaysia man! congrats dude....
Stock M106 spec: (Similar to M30 Block)
Engine Type = M106 3.5l Inline 6cyl
Displacement = 3430 cc
Stroke = 86mm / 3.386in
Bore Dia. = 92mm / 3.622in
KW/HP @ 4200RPM = 185KW / 252HP
Max Torque = 380Nm / 280lb/ft
Max RPM = 6200
Comp. Ratio = 8.0:1
Cam Shaft = 264/112
Piston Clearence = 0.04mm / 0.0016in
Valve Diameter = intake 46mm
= exhaust 38mm
PostPosted: Sun Nov 25, 2007 5:08 pm    Post subject: Re: RENAISSANCE OF THE E21 Reply with quote
Modified M106 Motor Data :
Modification to the 745 Motronic computer program allows unlimited increase in power and torque.
The practical increase is dependent on several other setups in the car and engine.
Typical increase is 100-150 hp together with some modification of wastegate or to wastegate's control system.
Power levels of 350 - 500+ HP and torque over 640 Nm are possible.
There are many ways to increase boost. You can either have a fixed boost level or a adjustable boost control.
One of the best boost control systems for 745's was the Tuoma Perfection adjustable wastegate,
but that is not available at the moment and may not be manufactured at all anymore.
The standard 745i 3.4 L engine gives 252 HP at 0.3/0.5 bar boost. Engine cutoff is set to 0,7 bar,
which many of the 745 owners have unfortunately experienced.
This modification to the computer program removes the cutoff limit and sets all necessary parameters for unlimited power.
The program is dynamic, so performance is optimal at any and no boost conditions. Torque is increased also considerably.
As a rule of thumb this program increases power by approx. 50 HP for each 0.2 bar step:
0.7 bar = 300 HP, 0.9 bar = 350 HP, 1.1 bar = 400 HP, 1.3 bar = 450 HP, etc...
The standard 745 turbo is good at least upto 1.5 bar.
andre1001
PostPosted: Sun Nov 25, 2007 5:13 pm    Post subject: Re: RENAISSANCE OF THE E21 Reply with quote
congrats buddy ,i imported the engine my own ,and between i can boost up to 1.8
andre1001
PostPosted: Sun Nov 25, 2007 5:18 pm    Post subject: Re: RENAISSANCE OF THE E21 Reply with quote
Laughing wanna join me for a test drive next friday Very Happy
PostPosted: Mon Nov 26, 2007 3:23 am    Post subject: Re: RENAISSANCE OF THE E21 Reply with quote
AAHHHHHHRRRGGGGGGGGG GILLLLAAAAAAAA!!!!!!
Respect sama lu andre! waahhhahahah.... sumpah tak nak test drive... mau tengok saja! kekekekek
Fuel pump awesome! i will make it tidy and display the whole assembly just like amplifier... its a total asset to the car!
again RESPECT!!!!
andre1001
PostPosted: Mon Nov 26, 2007 8:34 am    Post subject: Re: RENAISSANCE OF THE E21 Reply with quote
highway thanks big brother
PostPosted: Mon Nov 26, 2007 4:21 pm    Post subject: Re: RENAISSANCE OF THE E21 Reply with quote
mad respect man!!!!real bavarian monster in malaysia...kasi tunjuk ajar budak jap engine!rasa nak supercharge engine aku plak....tapi takda budget!
PostPosted: Mon Nov 26, 2007 7:13 pm    Post subject: Re: RENAISSANCE OF THE E21 Reply with quote
Wohooo....lu mmg btul2 pure bm monster la bro andre!!! Bro kasi shoot video la itu test drive, kita semua mau tgk keganasan keta lu!!!
Tabik springggg!!!
Page 2 of 5
