Online Now [1563]:
Visitors: 1563
Today: 75130
Total: 31186272
E28 Tak Pickup
reme28
PostPosted: Tue Oct 09, 2007 6:32 am    Post subject: E28 Tak Pickup Reply with quote
to all members i need help all of you for my e28.my e28 kurang pickup.it is like that for m20 engine ? because the old engine ? or must be tuning and the setting for pickup? the clucth plate ? i dont think so.you know when i want to memotong oledi must be change the 3rd gear and like the kancil car Sad
need advised please...........................................
PostPosted: Wed Oct 10, 2007 3:34 am    Post subject: Re: E28 Tak Pickup Reply with quote
Is your E28 M20 2.0? if want to overtake (anycars) sure you have to shift down to 3rd gear. Jarang2 overtake on 4th gear. Some crazy headed driver shift to 2nd gear...
Have this problem occured recently? or memang from day 1?
axle diff plays one of the problem BUT before you do that, please consider
Plug Cable, Rotor Arm, Distributor cover, Plugs, Fuel Filter, Fuel Injector.
Minyak Hitam naik plug tak?
if yes, piston ring koyak therefore not enough combustion.
reme28
PostPosted: Wed Oct 10, 2007 3:53 am    Post subject: Re: E28 Tak Pickup Reply with quote
yup m20 (2.0) manual.my foreman said my car like this because m20 engine and the body 528.i think that true the foreman said.my car body 528 ,and use the 2.0 engine.maybe berat kot Very Happy Very Happy Very Happy but when the long disctance its ok.my foreman try to kasi kuat api distributor for the pickup.this car no makan minyak itam.no leaking and engine good runing (stabil) .and minyak itam tak naik plug setakat ni.cuma my old e28 kalau 3-4 hari tak start bila nak start very difficult to start dia akan naik minyak ke plug.
drag86
PostPosted: Fri Nov 02, 2007 12:11 pm    Post subject: Re: E28 Tak Pickup Reply with quote
Twisted Evil Twisted Evil
drag86
PostPosted: Fri Nov 02, 2007 12:16 pm    Post subject: Re: E28 Tak Pickup Reply with quote
mine also the same problem. Just did the top overhaul and change alot of parts. (timming belt,rotor arm,distributor cap,bearing, water pump, blackoil pump,stater, clutch release bearing and also the gearbox "m")
I think maybe do transplant better...he..he..
