Online Now [1987]:
Visitors: 1987
Today: 78941
Total: 31190083
Window stuck!!!!
PostPosted: Tue Oct 09, 2007 4:47 am    Post subject: Window stuck!!!! Reply with quote
To all sifu...need ur help immediately,my window stuck (driver site) & after bedah siasat pomen gitau motor power window sudah kong & kos tukar motor (chop shop) around 300++ bcoz motor mai sekali with regulator,tak juai separated....btul ka??? Tak penah lg menghadapi masalah sebegini sblm nih....tolon....
PostPosted: Tue Oct 09, 2007 4:54 am    Post subject: Re: Window stuck!!!! Reply with quote
sudah try pakai switch lain?just in case switch jer yg rosak..
PostPosted: Tue Oct 09, 2007 5:04 am    Post subject: Re: Window stuck!!!! Reply with quote
Switch dah try OK,wiring pn dh check OK....kena bukak pintu la aku nk Touch&go balik raya nih..huhuhu
reme28
PostPosted: Tue Oct 09, 2007 6:20 am    Post subject: Re: Window stuck!!!! Reply with quote
aku pun dok carik pomen nak suruh cek aku punya power window belakang.kiri & kanan pulak tu.tean suis pun pun tak mau.tak tau mungkin suis atau wiring .tak pi check lagi.dulu e28 lama aku buat sedniri ok plak.tapi yg ni nak bukak cover pintu tu yg sayang tu.takut prap! patah pulak dia punya screw lock yg palstik dlm kulit pintu letih aku.baru ni tukar getah cermin belah driver ok dah la.tak bunyik angin masuk celah cermin.baru la sedap sikit sembang he he he
PostPosted: Tue Oct 09, 2007 7:31 am    Post subject: Re: Window stuck!!!! Reply with quote
Bro Bimmerasta, what my mech did was, to hit as hard as he can at the inner door (where the motor should be) and at the same time press the window lower button. Guess what, it turned out to be working after that. It just an old motor, need to wake him up once a while. Try it. No harm. Sakit tangan je =p
Bro reme28, for me I don't really bother about rear window coz nobody will open it pun. The most important one is the driver's side.
PostPosted: Wed Oct 10, 2007 12:06 am    Post subject: Re: Window stuck!!!! Reply with quote
kasi pakai Smart Tag la bro... ekeke.
PostPosted: Wed Oct 10, 2007 6:27 am    Post subject: Re: Window stuck!!!! Reply with quote
Oho..like that hah,ok i will try it...thanks bro for the special skill...sakit tgn pn takpa janji bleh bukak cam biasa...nk beli smart tag modal lg bro...huhu
PostPosted: Wed Oct 10, 2007 6:44 am    Post subject: Re: Window stuck!!!! Reply with quote
check your wiring betul2. from motor to your switch (inside door), got 1 small 2 pin connector (warna hitam, bentuk macam botol susu), buka dan kasi clean with WD40 dan try fiddle with the connector while holding your window switch down. Kekadang pin kotor so loss contact, kalau contact pun,
voltage tak supply penuh... kalau tak boleh, try bypass the connector. kalau masih tak boleh, while bypass the wire, have a slightly knock on your motor. if stilllll cannot work... motor KONG. uhhhh...
good luck!
PostPosted: Thu Oct 11, 2007 2:31 am    Post subject: Re: Window stuck!!!! Reply with quote
Bro aRRrgghh punya skill dah coba tp gagal....mau try bro Reiner punya skill plak...after cabut,clean & test with testpen connector kaler hitam (yg mcm botol susu tu) didapati ada supply in but no supply out to motor...i think motor KONG oledi lor....
Bro,ada beza tak motor for 2door & 4door???
Motor dijual berasingan or come completed with reel,cable & regulator???
PostPosted: Sun Oct 21, 2007 3:16 am    Post subject: Re: Window stuck!!!! Reply with quote
Done!! My motor already working after ketuk bertubi tubi dgn hammer..heh..heh..btul la motor dah tua,need to wake up him once a while,nasib baik tak tukar motor baru (cost 200++ but kena order dulu) Thanks to all forummers diatas idea & sokongan anda...orale!
PostPosted: Sun Oct 21, 2007 5:46 am    Post subject: Re: Window stuck!!!! Reply with quote
hahah .. dah agak dah =)
PostPosted: Wed Oct 24, 2007 2:43 am    Post subject: Re: Window stuck!!!! Reply with quote
For those who want an idea of how to service their power window motor, here's a link:
www.crunchyfrogpro.com...epair.html
PostPosted: Wed Oct 24, 2007 4:49 am    Post subject: Re: Window stuck!!!! Reply with quote
very good.... yup soon will do mine! wahahaha..
Bimmerasta can u please post it to DIY section aswell. Its a good tip!
boyhartge
PostPosted: Wed Oct 24, 2007 6:47 am    Post subject: Re: Window stuck!!!! Reply with quote
BRO....IF ADA BUNYI WAKTU TURUN KAN IA HOW?????NEED TO PUT OIL KAT MANE YE......SOUND LIKE CRACK CRACK CRACK HUH
boyhartge
PostPosted: Wed Oct 24, 2007 9:01 am    Post subject: Re: Window stuck!!!! Reply with quote
hahahaha....sudah di lakukan....tq to Mr_Bimmerasta.....hehehehe
