Online Now [1459]:
Visitors: 1459
Today: 68285
Total: 31026396
apa pendapat otai2
alipe36
PostPosted: Tue Feb 08, 2011 11:38 am    Post subject: apa pendapat otai2 Reply with quote
awal bulan 1 aritu aku anta keta aku wat blik gearbox.after repair rasa ringan sikit tp problem mcmtak selesai masih ada tesentak.pomen cakap mounting and bush axle kn buat bru ilang sentak tu.btul ker?aku buat kat member aku worshop kat kerinchi
View user's profile Send e-mail Photo Gallery
PostPosted: Tue Feb 08, 2011 2:20 pm    Post subject: Re: apa pendapat otai2 Reply with quote
tengokla mana yg dah ada free-play banyak.bush axle ke atau mounting
PostPosted: Wed Feb 09, 2011 3:07 am    Post subject: Re: apa pendapat otai2 Reply with quote
suspected long shaft coupling, or might be your rear axle gear Smile
masa repair gearbox ada tukar mounting sekali tak? kalau takde mounting condition okey ker atau dah kong? kalau kong kena tukar Smile
Please check the following
1. check long shaft coupling
2. u-joint longgar, hantar machine shop
(first part long shaft ke second part long shaft, universal joint U-Joint)
3. terpaksa turun gearbox pasang mounting baru
4. masih tak okay last resort rear axel
alipe36
PostPosted: Thu Feb 10, 2011 2:09 pm    Post subject: Re: apa pendapat otai2 Reply with quote
pomen aku dah repair skali long shft and wat alingment blik.ada la gak cooper bush yg rosak dah tkar.dia ckp tinggal all bush and mounting axle kn buat.tula target bulan depan bru nak buat.thanks boy and highwaystar
