Online Now [2056]:
Visitors: 2056
Today: 25099
Total: 30983210
::: E30 M40 AFM Ada Masalah. Help Needed!
PostPosted: Thu Sep 28, 2006 2:56 pm    Post subject: Re: ::: E30 M40 AFM Ada Masalah. Help Needed! Reply with quote
From digest.v7.n902 Thu Jan 8 14:47:14 1998
Date: Thu, 8 Jan 1998 11:08:51 -0600
Subject: <M30> Re: Big 6 air flow meter tinkering
>From: "John G.Burns" <john_at_unixnerd.demon.co.uk>
>Date: Thu, 08 Jan 1998 0:10:37 GMT
>I have read of the need for this procedure in the BMW
>Enthusiasts Companion p93. It says that "BMW Fuel Injection:
>An Enlightened Approach" contains the details of how to do
>this "straightforward" procedure.
>I have an '85 635CSi with 142K and am respobsible for two
>friends 520i's which both have over 100K. In one 520 the
>idle adjust screw has bottomed out which I believe is the
>sign that spring retensioning time has arrived. Any adivce
>is appreciated.
is 'BMW FI: AEA' still in print? i'm pretty sure it isn't; mine is a spiral bound book from Metric Mechanic and covers only K and L Jetronic.
the AFM recal is pretty straightforward; you add tension to the spring to lean out the mixture, release the spring to richen. spring tension cal works across entire rev range, CO scew adjust affects only the idle mixture. Back it out to lean, screw it in to richen.
Hints:
0. get spark system in order before doing
anything on the fuel system.
1. paint a dot on the spring wheel and
a corresponding dot on the AFM body; this is helpful if the spring spins wildly during adjustment.
2. ajust richness/leaness at 2500-3K RPMs
by pressing the flapper which moves the pointer on the wiper track; monitor the O2 sensor to see how much adjustment you need and change spring tension accordingly. one tooth at a time is best.
on my L-jet cars, i do this with 02 sensor open loop; i have no idea how a Motronic car responds to open loop O2 operation.
'BMW FI: AEA' recommends finding
this sweet spot by ear.
3. i thought the early Motronic cars had
a dip switch in the control unit
for minor adjustments to the richness and spark advance; i've heard this referred to as the 'Fuel Quality Switch'. that's all i know about it
eric tangen
dewahujan
PostPosted: Mon Feb 07, 2011 5:16 am    Post subject: Re: ::: E30 M40 AFM Ada Masalah. Help Needed! Reply with quote
dh cuci cui jgn lupa reconnect bateri lebih kurang 30 minit utk reset blk... hepi mencuba...hhuhu
View user's profile Send e-mail Yahoo Messenger ICQ Number Photo Gallery
PostPosted: Tue Feb 08, 2011 4:34 am    Post subject: Re: ::: E30 M40 AFM Ada Masalah. Help Needed! Reply with quote
Dude, since my last post in 2006 (that long!) I've serviced the AFM, not DIY my mech done it. Can last few years. And after that, it happened again. Now using another AFM. Got it in good condition @ RM450. Not sure how long it will last =)
qu88
PostPosted: Tue Feb 08, 2011 3:05 pm    Post subject: Re: ::: E30 M40 AFM Ada Masalah. Help Needed! Reply with quote
reconnect?klu x wt pe efek nye bro?
dewahujan
PostPosted: Wed Feb 09, 2011 4:51 am    Post subject: Re: ::: E30 M40 AFM Ada Masalah. Help Needed! Reply with quote
dlm ebay termasuk shipping GBP55.00=+-RM26x.xx
