Online Now [1820]:
Visitors: 1820
Today: 187637
Total: 31128086
opinion needed...!
PostPosted: Thu May 03, 2007 8:40 am    Post subject: opinion needed...! Reply with quote
as u guys know... my E30 involved in small accident kan. so, left front lights ada skit short dan "terkulai" (kat sebelah dalam grill la). maknanya,... housing (sarang yang pegang lampu) untuk lampu tu pecah but luckily lampu tak pecah... cuma tak menyala je. jadi,... soalan saya,
1. bleh ke kalau nak beli housing tu saja atau kena beli dengan lampu skali?
2. kalau bulb terbakor, nak kena tukar sebijik lampu ke tukar bulb dalam je?
PostPosted: Thu May 03, 2007 4:17 pm    Post subject: Re: opinion needed...! Reply with quote
encikbmwhitam, saya try jawab ya:
1. Depends kat kedai potong yang dikunjungi. IF u r lucky, they will give u ONLY the housing. If not u haveto take the whole lot.
2. Tukar bulb je bro. Nak tuka the whole lampu wat per kekekek
PostPosted: Fri May 04, 2007 4:24 am    Post subject: Re: opinion needed...! Reply with quote
orait... thanks bro arrrgghh. maksudnya saya kena tukar SEKETUL termasuk hi-beam la yer?
soalan saya lagi,...
1. berapa yer budget untuk WHOLE LOT lampu tu yer?
PostPosted: Fri May 04, 2007 4:54 am    Post subject: Re: opinion needed...! Reply with quote
whole lampu assembly will cost around 400-500 per set left and right (lampu telor) lampu biasa about 250 - 300 per set (memang susah nak cari dah)... Smiley jarang jumpa and i bel it is a bit higher.
Cheerio!
ohh P/S
If nak tukar bulb, please check the correct wattage BMW ori use 55W Phillips or Osram. Kalau sebelah 100W and the other 55W, sure your bulb will burn easy.
PostPosted: Fri May 04, 2007 7:05 am    Post subject: Re: opinion needed...! Reply with quote
erk...!
mak aih...! yang biasa pun makan ratus?!! err... angel eye pulak harga macamana? hari tu bro highway ada cakap kena special order kan? order kat sapa yer? (banyak pulak soalan aku Embarassed )
kena beli cincin kawin dulu la baru bleh beli lampu... uhhuhuhu. kalau macam ni lambat lagi la saya nak join 2t. tak bleh lagi ar nak join konvoi memalam. uuwwaaaaaaa......!!! Crying or Very sad
PostPosted: Fri May 04, 2007 6:17 pm    Post subject: Re: opinion needed...! Reply with quote
Bro, tuka which bulb yang terbakar je. If the high-beam bulb tak terbakar, tak yah ler.
Whole lot lampu as per Bro Highway cakap la RM250 - RM500 kat kedai potong. Depends beli kat mana or jenis keadaan dia.
Nak 'angel-eyes'?. I've got stock cun for E30. Harga melebihi RM1k. PM if interested or click HERE for the link.
PostPosted: Sun May 06, 2007 1:18 am    Post subject: Re: opinion needed...! Reply with quote
owh... thanks bro. yang sekali high-beam tu i mean the whole lot (housing) tu. if i just change the bulb, the housing still broken... lampu goyang2 jugak bile bumping nanti. maknanya saya memang kena cari housing jugak. anyway, i'll try my best to work it out. thanks again bro Very Happy
erk... over 1k??!! wah sai... cantiknya. can't imagine lampu tu kat E30 saya. hohoho. Twisted Evil
saya memang interested pada 'angel-eyes' tu. very very very very interested. tapi buat masa sekarang i have to use the money for wedding dulu. nanti kalau ada budget lebih baru i PM bro arrrgghh yer. go go 'angel-eyes'... chaiyok chaiyok...!!! Very Happy
