Online Now [1527]:
Visitors: 1527
Today: 3147
Total: 31132329
Overheat!!
bruised
PostPosted: Sun May 06, 2007 11:56 am    Post subject: Overheat!! Reply with quote
Happened a few times already.... kete overheat waktu jem. Check everything seems okay then noted fius for the aux fan burnt!!. Replace the fius and everything looks OK after that. Dah ganti 3x dah.... everytime jem tgh panas fius blow. Any idea why fius blow??.... Aux fan motor dah kong ka? Ker kena tukar keter baru?? hehehe
PostPosted: Mon May 07, 2007 2:10 am    Post subject: Re: Overheat!! Reply with quote
Might be the wiring problem bro maybe something wrong with your relay, whenever the current kick into your fan, the fuse cant hold it, then it will burnt due to current overload. Please do check all your fuses configuration amphere correctly. Some accessories shop main letak jer. BMW fuses very particular about electrical management. If your fuses is 7.5 amp then letak 7.5 jangan letak 10 or 15amp, kalau salah amp, most probably it will burnt other fuse aswell. DO CHECK YOUR FAN RELAY, over the year, most relays get aging, therefore it will not function properly. Please change new relay (cost about RM40)
your fan also must check ahh. ok i dont know much about your engine, normally overheat case, the most basic thing is to check..
1. Water Pump
2. Water got or not
3. Fan Clutch
4. Fan belt
5. Hoses
6. Radiator
7. Fan relay
Good Luck!
jo-e34
PostPosted: Mon May 07, 2007 5:29 am    Post subject: Re: Overheat!! Reply with quote
not to forget your thermostat.......
PostPosted: Mon May 07, 2007 7:12 am    Post subject: Re: Overheat!! Reply with quote
oh yes..how come i forgot about that..yup bruised thermostat aswell. Thanks jo-e34
bruised
PostPosted: Mon May 07, 2007 10:11 am    Post subject: Re: Overheat!! Reply with quote
thnax alot la bros... will send the car to mechanic this weekend after my exams. No time time lar now. Libido pun kurang
jo-e34
PostPosted: Tue May 08, 2007 4:27 am    Post subject: Re: Overheat!! Reply with quote
no prob boss.....just sharing my experience........ Smile
PostPosted: Tue May 08, 2007 6:51 am    Post subject: Re: Overheat!! Reply with quote
bro pomen kat golok tahu nak repair keta ..huhu
bruised
PostPosted: Wed May 09, 2007 7:55 am    Post subject: Re: Overheat!! Reply with quote
ko jgn underestimate diorang nie.... arit tu aku tgk dia tgh calibrate blk activ steering 5 series..... btul tk btul aku tk tau lar pas tu hehehe
